How do I reset a 622? | SatelliteGuys.US
jhall299
23
Something vetter than unplugging it is prefered. Is there a way to default it to it;s original config? Is the proceedure the same for a 211?
Jon
Jon
Jhall,
The only way to reboot the receiver is via pulling the electrical plug, or by opening the right access door and pressing and holding the Power button til the BOTH the receiver's TV1 and TV2 LED's light up.
If you want to set the receiver back to its factory defaults that can be done from the receivers Main menu.
John
Newbie Questions for VIP 622 rcvr
new distant networks- awful quality??!!
