How do u chnage lnb type on new hd dvr dtv receiver? | SatelliteGuys.US
dinger59
2
I have a brand new HD DVR DTV Reciever and took out to garage to hook up to old dtv lnb type dish but it says does not recognize. How do you chnage lnb type
First, :welcome to Satelliteguys!
Which dvr and what model lnb and dish type?
Menu
Parental Favs & Setup
System Setup
Satellite
Repeat Satellite Setup
Select the proper dish from there
However, if he is just moving it to a standard dish but you are getting a "searching for satellite signal" then it would be easier to just un hide SD duplicates.
If the receiver has been connected to SWM then when you are in sat setup make sure you select "multiswitch" first, then the other dish types will become ungreyed and you can select them.
Just got a HD DVR off ebay now have a question
Any plans for ID (Investigation Discovery) in HD?
