How does 622 decide which satilite's signal to display? | SatelliteGuys.US
RBODYMAN
13
SIMI VALLEY,CA
I have a 622 & 211 installed recently. I have 3 dishes that see 61.5, 110, 119 & 129. How does 622 decide which satellite signal to diplay when voom, espn2hd and universal hd are on 61.5 and 129? Signal strength on 61.5 is much higher than 129.
richard
I have the same set up. I have 61.5 hooked to port3 and 129 to port 4. When I do signal strength it shows 61.5 for VOOM, etc.
I swithced 61.5 to port 1 and 129 to port 2. going to menu 6 1 1 (check switch) still shows 622 using 129 for high def channels. My signal strengh is barely acceptable on 129 while 61.5 is much stronger. Any other ideas?
Receivers - How many is too many
Local Channel Transponder Differ on 311 to my 522
