AMIKO - How does the Big2Small app work? | SatelliteGuys.US
AMIKO How does the Big2Small app work?
Alan Rovner
201
115
Vancouver, WA
Hi again friends, I changed from an A3 to a Mini HD SE receiver, and came across the Big2Small app on Amiko's web site.
It doesn't seem to do anything or connect to the receiver. How do you run this app? Both my phone and receiver are on the same network. The receiver is wired and the phone is on WiFi.
Thanks as always,
Alan
Grab the ALi version rather than the one on the Amiko sites. It works better with the later software: https://play.google.com/store/apps/details?id=com.alitech.dvbtoip
I'm not in front of a Mini and it's been awhile since I messed with it streaming but you'll find an option in the Mini, something like Big2Small Server. Be sure that is enabled/on. Obviously be sure your Mini and target device have a network connection then launch the Big2Small App. If all is well it should find your Mini and allow streaming and basic control.
