I could spend an inordinate amount of time searching the forums for my answer, but with so many brilliant members here
D
), I figured I'd just ask you directly!!
How does the "Primetime Anytime" feature deal with shows on the same network that "hot switch" between them. (that is to say, one show's storyline ends, and the next show IMMEDIATELY begins after only a moment of black between them?
With my current setup (ViP 722), I usually have to set up one recording for the first show, and extend it by a minute or two, so that I make sure to get the last moment of the show that comes on after the last commercial break. Of course, since I have extended that recording, my next show has to start recording on the other tuner.
Basically, I'm wondering if the new PTAT feature will somehow solve this, or will bits and pieces of shows be stuck to the beginnings/endings of other shows!
Hope that made sense, and hope someone has an answer!!
