How many HDTV's in one household? | SatelliteGuys.US
huskerhead
254
42
Urbandale, Iowa
A co-worker has Dish Network and just added two more HDTV's for a total of four in his house. He was told by Dish that he cannot have more than three of the four HDTV's hooked up to an HD receiver. I went to their website and did the builder - and sure enough it only allows three HDTV's per household. Are there any work-arounds so he can have all four hooked up to HD receivers?
He can buy extra 211 for $99 . if you go to radio shack or sears they have 211 that yoiu can buy. getting one from dish might show up as a $99 lease so your better off getting it local.
When placing the new order make sure to inform dish you will have 4 recivers as curent 1000.2 or 1000.4 dish will only suport 3 recivers and a 44 switch will be required.
Maybe that's why they don't want to give you 4 stb's because of the DPP44::deal:
Out of Contract Upgrade
question about cincinnati locals in hd
