How much does a Dish 300 install cost? | SatelliteGuys.US
G
Guest
Guest
For those of us who were waiting for SuperDish to get HBOHD and SHOHD what does it cost to get a Dish 300 installed?
Are folks with no locals on 61.5 SOL or at least out of $$$?
Anyone have luck getting a 61.5 Dish 300 installed for free when their 6000 was installed?
TIA
Buy one on eBay. Shipping will cost more than the dish. Install is easy. Do it yourself.
http://search.ebay.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Fws%2F&MfcISAPICommand=GetResult&ht=1&from=R7&ebaytag1=ebayreg&query=Dish+300&query2=Dish+300&search_option=1&exclude=&category0=&minPrice=&maxPrice=&ebaytag1code=0&st=&SortProperty=MetaEndSort
But switch is required, right? For a 921 a SW34 would be needed. Another $100 to the 921 tally :shock: ...
Is one of your locals on a side slot, if so you can get it for free.
Friday I'm getting a dish 300 and a dp 34 switch for free because of that 1 local channel.
An install could cost as much as $100 or more depending on who you have do the installation for you. If you have your existing retailer have the dish put up for you then you would probably get a better deal, perhaps half of that. The cost of the dish would probably be around $50 but could also be more but can be had for cheaper depending on where you get it. The switch would be in addition to the dish and installation.
