How reduce weight on Actuator on 8' Dish | SatelliteGuys.US
SatPak
3
2
Islamabad, Pakistan
I have a 8 footer solid iron dish which I feel is quite heavy for my 24" actuator (rated at 600 lbs). When the dish goes to extreme East (10 E) (I am at 73E) I feel the actuator has to work hard as the dish moves slower until it reaches the 25E then gains speed.Also it sounds heavier.
Any idea how can I help the actuator ? I was thinking of adding a 20Kg weight on the other side of the dish and also later found somebody already doing it (https://protechparabola.files.wordp...h-terpasang-pada-mounting-parabola1.jpg?w=900). Any better ideas?
Once I figure out how I'm going to modify my BUD mount to go lower, than 55W, I am adding a counter-balance weight. (25+ yr old VonWeise & 100% Steel BUD)
Similar to one shown here but modified for use on a polar mount.
Fat Air,I hope it doesn't cost you as much as the set-up on that link. :eeek Egads!
