How Safe are Mobile Signal Boosters? | SatelliteGuys.US
As cellular devices become more widely used, the need to boost mobile signals continues to grow. Mobile signal boosters are handy devices that help you stay connected even when you have a weak signal. They are used in hospitals, schools, homes, vehicles and businesses.
There are many myths floating around the internet about how safe it is to use cellular signal boosters. In this article, we highlight three main reasons why mobile signal boosters are safe. But first:
What Is A Mobile Signal Booster?​
A mobile signal booster is an electronic gadget that amplifies and improves a cellular signal within a vehicle, homestead or building. These boosters can amplify a 5G, 4G LTE, 3G and 2G mobile signal up to 1,000 times. This device enhances connectivity and improves your call quality, data speed and messaging reliability. Using it also results in fewer dropped calls.
Mobile signal boosters work by pulling radio frequency signals from the nearest cell tower using an outside antenna. The outside antenna can be mounted on a car roof or an exterior wall. It then amplifies the voice and data signal and passes it to an inside antenna. The inside antenna rebroadcasts the signal into the interior space of your building or vehicle so your phones and other devices can receive it.
The booster can detect weak or faint signals and amplify them even when obstacles are in the way. When your mobile phone transmits a voice or data signal back to the cell tower, the process above is repeated in reverse order while bypassing any obstacles present.
Keep in mind that a cellular signal booster cannot create a working signal where there is no coverage. It will only work when you have at least one bar. Also, a booster cannot boost satellite, cable WiFi or internet signals.
Benefits Of Using Mobile Signal Boosters​
There are several advantages you’ll get from using a mobile signal booster. A few of them include:
  • Improved convenience – When using a cellular signal booster, you no longer need to move around or go outside to make a call or send messages. You can get good reception and connectivity from the comfort of your home, office or car.
  • Improved employee productivity – Your team will no longer struggle with poor network connectivity, which can help them to do more in less time. For instance, your customer support team can call more customers with the good signal provided by the booster. If you use a signal booster along with one of the best project management software as recommended by Cloudwards, you will unlock the full potential of your team.
  • Improved employee turnover – Employees can give better results and hit set targets with a good connection. Therefore, using a mobile signal booster will help boost your team’s turnover and overall employee satisfaction.
  • Remain connected on the move – When on a road trip or driving to areas with weak networks, a cellular signal booster will help you remain connected as long as you have electricity and at least one bar on your phone. RV users particularly enjoy using signal boosters on the move.
  • Works with solar panels – Mobile signal boosters can also run on the power provided by solar panels. Therefore, you can use them in off-grid cabins and other remote locations that have a weak signal.
  • No increased data rates – Using a cellular signal booster will not increase your data rates because it does not use any data to function.
Remember, you don’t need an internet connection for your mobile signal booster to work. As long as you have electricity and at least one bar on your phone, you’re all set. You also don’t need to manually connect your mobile device to the booster. If you’re within range, your device will automatically get more bars.
Are Mobile Signal Boosters Safe?​
Mobile signal boosters are safe when they are installed and used appropriately. Let’s look at a few reasons why we consider these boosters to be secure.
1. They Are Regulatory Compliant​
Reputable companies are usually careful to comply with the policies set by regulatory bodies. In the US, every mobile signal booster has to be tested and certified by the Federal Communication Commission.
Therefore, when you buy a mobile signal booster from a reputable company, you can be assured that it will work as the manufacturer claims. This includes adherence to strict technical standards and specific power limits. It also will not interfere with your cellular network.
The Industry Canada (IC) certification is the FCC’s equivalent in Canada. So look out for the FCC or IC logos on any cellular signal booster that you buy in these countries.
2. They Produce Lower Electromagnetic Radiation​
Mobile phones emit low-frequency electromagnetic radiation when in use. Using a mobile signal booster can reduce the amount of radiation emitted by your cell phone. This is because the booster allows your phone to operate on less energy. This results in lower electromagnetic radiation.
To get the best results, make sure to invest in a high-quality cell booster that’s big enough to meet your intended use without using excess power. For instance, if you’re in a 1,000-square-foot office, you don’t need to buy a booster designed for 4,000 square feet. An unnecessary increase in signal strength means an unnecessary increase in radiation.
3. They Maintain Data Security​
In the modern era, data security is a key concern. The million-dollar question therefore becomes, “Do mobile signal boosters make me more vulnerable to attacks?” The answer is no. Cellular signal boosters are as secure as the network they are amplifying.
In other words, if you’re using a secure network, then the booster will not make you more vulnerable to attacks. Therefore, you can use your mobile signal booster with the confidence that your data is safe.
Conclusion​
Mobile signal boosters are safe to use and provide you with better connectivity, whether you need it in an office setting or while exploring the great outdoors in your RV. As long as you buy and use a booster that’s compliant with the set communication regulations (like FCC and IC), you’re good to go.
Boosters do not interfere with your data security. Mobile signal boosters are as secure as the network they’re amplifying. You can rest assured that they do not make you more hackable or prone to attacks. They can also help your phone produce lower electromagnetic radiation by making sure it doesn’t work too hard when looking for a signal.
The post How Safe are Mobile Signal Boosters? appeared first on The Solid Signal Blog.
Continue reading...
