Per Earl at DBSTalk.Com
CE's: How to enable DIRECTV on Demand
Well... you have asked... you have predicted...
Some of you were wrong, some of you were right.
The HR20-700 0x190 introduces DIRECTV on Demand to the CE program.
And how else would you expect it to be activated: a Keyword search and the Misc. Option menu.
Keyword Search: IWANTMYVOD
Front Panel: Menu & Info
Displays the updated screen: Misc. Option Screen
Tip: remember to select OK on the Misc. Option Screen.
Tip #2: remember to check your channel filters
Tip #3: If after an hour or so, nothing enables... try a reboot.
After enabling the option, some features may not fully enable immediately.
Remote Booking will not be automatically enabled by this procedure, that feature/option will be enabled over the next few weeks.
Somethings to note:
Enjoy...
Also: Even if you don't have a network connection... I highly recommend you at least do the search, and enable the VOD option.... that way it will give more testing feedback on the CE as a whole, even for those that don't want to use VOD... but the components are there...
To get some ideas on how it all works... check out the First Look: DirecTV On Demand
Somethings to note:
- If it doesn't work after a few hours, it might not be you or the HR20. There is another component to DIRECTV on Demand that has to be activated on DIRECTV's side. And we will be working with DirecTV to resolve those issues...
- If you don't have your HR20 network, then it won't be available to you.
- Report, Report, Report, any and all issues and comments. Details, details, details.
- At a minimum we will have two additional threads: VOD Issues, VOD Recommendations be sure to post in the appropriate treads, and if you think a new one is needed feel free to start one.
Enjoy...
