How to Add Galaxy 18 to ProgDVB | SatelliteGuys.US
satcom1
364
Near Chicago
C:>program files > transponders > all > open with Notepad. scroll down to 2370=Galaxy 10R > insert 2368=Galaxy 18. OR cut 2370=Galaxy 10R and add 2368=Galaxy 18Scroll down 70% to below [2350] above [2370] insert [2368] and copy and paste all of the Galaxy 10 R Frequencies OR just rename [2370] > [2368].Save >
More info.
This works for ProgDVB Ver. 5-14-08 or higher. That should be:C:/program files/>ProgDVB/>transponders/>all- Open with notepad. Make a aii.bak file before you edit.
Do any dvb-s pci cards work on vista 64
Trimax 1100
