how to add more receivers | SatelliteGuys.US
mike_ayu
22
After having another switch mounted on my roof go bad, my installer replaced my 2 antenna setup with a new single triple LNB antenna (not sure which model as it just says Dish HD on it, no model number that I could find.) The new antenna just has 2 cables and these currently are used for each of my two existing receivers. I'd like to add 2 more receivers, but not sure if/how I do that. I assume there would be a switch that I run the 2 cables coming from the antenna to and split to 4 cables that run to each receiver (each receiver has a triplexer as they are all dual tuner receivers.)
Was thinking something like the DP34 would work? Can I actually run 8 tuners off the one antenna (sure hope so!)
Mike
No. DP 34 is runnin only one tuner per port. You'll need DPP44, and you need 3 cables going from antenna to switch. One for each lnb.
Posted Via The SatelliteGuys Reader App!
Martinash is right for 4 dual-tuner receivers. But, if you're willing to get by with only 3 dual-tuner receivers, your existing dish will work just fine (with the addition of another cable).
8 tuners or 4 dual tuner receivers? Either way DPP44 would be easier, but cascading several DPP33 would work as well. I'm not sure if the cost would be cheaper or not. (Tired, I guess I didn't finish reading the OP, Opps)
Its a Tad bit hard to cascade DPP 33 switch he's since they don't have passthru ports.......
One 44 into a 33 yes. Not more than 1 33 though.
See picture
No pass thru....
You'll need DPP44, and you need 3 cables going from antenna to switch. One for each lnb. Posted Via The SatelliteGuys Reader App!
That only depends on what setup it is. WA - yes one for each of the three sats. EA - not likely two would be fine as long as 77 is not needed for locals or Spanish programming.
FXX snags exclusive rights to 'The Simpsons', how will this effect Dish
Dish Anywhere - Can't log in
