How to change default blind scan settings? | SatelliteGuys.US
comfortably_numb
20,228
31,256
Kansas City
Anyone know how to set default blindscan settings in the PLi-based images?
Currently running OpenPLi and I have to adjust my blind scan settings every time I initiate one.
Would be nice to be able to set defaults and not have to adjust them every time.
Reactions: Brct203
i was also wondering the same for the TNAP image. I like the Scan to Transponder option, and I don't like that it always wants to clear the existing channels before scanning
Have to be able to modify the blind scan plugin located at /usr/lib/enigma2/python/Plugins/SystemPlugins/Blindscan
No i'm not smart to do it, one mistake and you get crash.
As for TNAP you can replace to blind scan folder form the Satdreamgr-6 image dated around the same time as TNAP January 2019 and reboot the box and then you will have the original Satdreamgr Blind scan. Backup your TNAP image first.
