How to clean out your DIRECTV Genie series manager | SatelliteGuys.US
It’s been a long time since there’s been any scripted TV to watch, at least on DIRECTV. Whatever you think about the actors’ and writer’s strikes, whether you think they were justified or not, they happened. And they essentially killed the fall TV season. We’re seeing a slow trickle of scripted shows coming in, and that means you actually might have something to record. If there are new things to record, you might want to take a moment and clean up your Genie’s Series Manager.
Why worry about it?​
Your DIRECTV DVR can record 100 series. That’s a pretty high number but not infinite. That 100-series-link limit has been around since the days of the HR34 in 2011. Before that it was lower — only 50 series. Back then keeping an eye on your recordings was pretty important.
You would think that if the folks at DIRECTV wanted to do so, they could increase that number or make it unlimited. In fact, TiVos had unlimited series links almost 20 years ago. But whatever…100’s still a pretty high number. If you need more than that, you may want to think about a DIRECTV for Internet subscription instead. DIRECTV for Internet has an unlimited cloud DVR, although you can only store programs for 90 days.
Still, if you don’t pay attention you’ll eventually use up all 100 spaces and then you won’t be able to record any more series. You’ll end up frantically cleaning things out in a hurry. It’s better to just do the cleanup as you go.
There’s another benefit: If your DVR is doing all the math to find all those canceled shows, it’s working harder. This could mean it slows down while you’re trying to do other things. In the past, keeping that series manager clean was the easiest way to make sure that you had a nice speedy experience. I’m not sure that’s still true but it’s still worth doing.
Finally, if you know a show has been canceled, you should clean out its recordings so you don’t potentially record a lot of reruns. Some channels aren’t real great about guide data and sometimes you’ll end up seeing a lot of reruns in your list. Again, you’re stuck cleaning them out.
Here’s how you do it​
Press the LIST button on your remote.
Then press UP to get to “Recording Manager.”
Then press SELECT.
You’ll see the screen above. Arrow over to “Series Manager and press SELECT.
You’ll see a list of all the series you have set up to record. Press the (R) button (not the red button) to delete a series link.
You’ll have one more “Are you sure” where you have to arrow down and press SELECT to cancel all the upcoming episodes.
This sounds like a lot of work but it really isn’t and it goes by pretty quickly. You can arrow up and down to go to different series and delete them pretty quickly if you want.
This is perfect for getting rid of those limited series that aren’t coming back, or those shows you’ve just given up on. It’s also good for any show that you completely forgot that you started watching because it fell off the schedule a year ago. Yes, that’s happened to me.
Sharpen the saw​
There’s an old book that called this sort of periodic maintenance “sharpening the saw.” It’s a good idea to spend a little time every so often just making sure everything is set the way you want, and then you won’t run into trouble later.
If you’re ready to upgrade to the latest and greatest DIRECTV programming, there’s one place where you can find out all about the newest offers and the best equipment. Solid Signal has been a DIRECTV dealer for over 20 years and we specialize in helping people like you. Call us now at 888-233-7563. If it’s during East Coast business hours, you’ll get a real DIRECTV tech who can answer your questions. If it’s after hours, no problem! Just fill out the form below. We’ll get back to you quickly!
The post How to clean out your DIRECTV Genie series manager appeared first on The Solid Signal Blog.
Continue reading...
Who Read This Thread (Total Members: 7)
