how to configure Circular Polarity on C Band LNB | SatelliteGuys.US
jermaine
13
Hi,
Iam from Portugal, and i want to get the sat NSS806 on 40,5 W circular polarity
This sat has only channels in C band, but in Europe most os sats are in KU band. So, i need a litle help, to configure an C band Lnb for circular polarity.
I have not experience in working with C Band Lnb´s.
Thanks,
Best Regards,
Antonio
most of the newer lnbf's sold today accept a di-electric plate and has a slot that it slides into on the feedhorn this will gain the circular polarity ( this di-electric plate is usually sold with the new lnbf)
hope this helps and welcome to the group.
Thanks for your help. Wich lnb for C band you recommend, for a prime focus dish of 1,8 m.
Best Regards,
Antonio
Is this dish going to be fixed on just that one sat, or motorized? If it's going to be motorized, I'd use something like a Chaparral wideband feed, since this will do both circular and linear C band without you having to go out to the dish and remove/install the dielectric plate every time you want to switch between the 2. I use one here and am getting good performance on both circular and linear. If it's just a fixed dish, then yes a cheapie C band LNBF with a dielectric plate is probably fine.
3 receivers to Hook up
AMC 3 - 4043 Radio mux
