How to control the 22Khz and DiSEqC in RitzDVB? | SatelliteGuys.US
gong
25
I have jsut install the RitzDVB for the 102G. I have troble to select the T5 satellite. My T5 settting is 22Khz is on and DiSEqC port is 4.
How do set the following value in the ini [LNB] section LOF1, LOF2, LOFSW, DiSEqC and DiSEqCType?
Also in the Hardware/Channels&LNB after choose a ini file, I don't know what to choose for Diseq/QAM dropdown list. Please help if you get RitzDVB working on your system.
Problem solved by modifying the ini file
After go to RitzDVB website, I found out a discussion relating the DiseqC and 22Khz switches setting infomation. I followed the infomation and making changes in the ini file. It is working now.
Gong
Sadoun Discount??
Upside down dish mounting
