How to convert Digital to Analog for multiple TV viewing ?!!! | SatelliteGuys.US
sol_xpert
2
Hello , I need your help …
I have Dish and a Digital Receiver installed and
working just fine to watch free to air channels on ONE , TV.
my question is ,
how can I send the signal through a coaxial cable
in order to connect other TVs and each TV
can view a different channel without having multiple receivers ?!
how is that doable ? what equipment do I need ?
any help you can offer would be greatly appreciated . :)
KEN , not even if i use some sort of computer , with some satellite card ?! and there isn't any kind of equipment for such task ?! you mean distribution networks use multiple stacks of receivers to accomplish this ?!!!!!! how come none of the receiver manufacturers like Nokia or Humax or Strong , etc ... never created a solution for such need and i know it is a widely needed feature !!!!!!!!!!!!!!!!!!!!!!! JUST wanted to see if anybody has anything to say about this ...... thanx .
So what's the problem? Get Voom and you're all set as far as the coax but you can't watch different channels.
A Dish 522 or 322 receiver will do this since they're bascially two satellite receivers in a signel box. There is no other way to do what you want, one satellite receiver/tuner will handle one and only one channel at a time.
S
Video-on-demand gets new focus
Taller Mast
