How to direct enter local digital channel on 622?? | SatelliteGuys.US
swingler
7
I must be slow, but I can't figure out how to direct enter a channel number like 25-3. Can somebody tell me how?
mdonnelly said:
Try 0253.
Four digits will work in the case of most digital channels (depending on how your local channels are numbered) but you can always be assured that you get the right channel if you enter five digits. In the case of 25-3, the number to enter would be 02503.
Can You Use a Tivo with Dish Network?
622's UHF Remote Distancevs the 522' UHF Remote Distance
