How to edit program title | SatelliteGuys.US
horseshoe
90
Pittsburgh, PA
Often CBS runs late onSunday due to sports so part of the Mentlist is cut off. To solve this problem I create manual timerson my second hopper. Now I get theMentalist but the icon and the name is of the news program that follows. I want to rename it back to the Mentalist andput in an episode number before copying it to my EHD.
Clicking edit does not give the option of changing the name. I could alwaysedit the name on by 622 and 612 so I'm sure the more advanced hopper should beable to do it.
Can somebody tell me how to edit the name?
Recordings can not be renamed. One of the few steps backwards for the Hopper, and related to lack of list editing. If i recall, there was a reason for it, but it escapes me at the moment. Best you can do is create a Mentalist folder, and move those manual recordings into it.
https://support.dish.com/viewtopic.php?f=11&t=3969
The other thing you could do is record Mentalist as usual from the guide (not via PTAT), and add an hour to the end time. You'll probably start off with some of the Good Wife, but the name will be correct.
Is it possible to swap hard drives on two vip722k receivers?
dishanywhere video problems
