how to get 1000plus install by dish? | SatelliteGuys.US
goldengoose
185
We will be moving soon. Yes really moving --not pretend moving
It sounds like the 1000 plus will be the only way to get 129 and HD in Central Oregon. We won't have room for two dish install, very narrow front of house and small yard situation.
Will Dish install the plus or is that something we have to pay for. It could make a difference to stay with Dish or make the jump to Direct.
The dish 1000.2 is all you would need for 129. The plus is for customers who need programming from the 118 bird.
I thought it (the plus) was a little larger dish for reception in these areas. I'll check about the 1000.2
625 and local HD signal
Dish lied to me need help.
