How to get audio from VIP 612 to computer speaker? | SatelliteGuys.US
chong67
35
Jonesboro
I have a nice computer speaker that has 3.5mm as the input.
I have the VIP 612 HD receiver.
Can I get audio to my computer speakers?
1. Get a two Male RCA to female 3.5 mm adapter right?
2. Will I get true L and R audio or I get same volume from both the speaker?
3. My computer speaker got the Power gain knob , that will amplify the signal right?
4. What are the things I need to do digital audio and the back of the 612 got it.
Yes, you can go from the red/white analog output of a 612 to the input of amplified computer speakers.
There are two digital audio outputs on the back of the 612. The HDMI output, which some folks feed to a surround sound receiver before going on to the TV, and the optical SPDIF jack. I've seen a few computer speakers that can accept SPDIF optical. If yours can, then just buy a toslink fiber cable and you're done. Otherwise, that too will probably need to get fed to a surround sound receiver via fiber cable.
I think I want to the cheap route. I will just do the RCA and I will running it thru a 25 ft cable to the computer speaker. I wonder if I will get any signal loss.
It will separate the audio to L & R, I hope.
If you have a HDTV just use the audio out from the TV. That is what I do since I have creative speakers hooked up to my TV. Hooking up from the 612 causes a echo effect when I have the sound from the TV speakers on at the same time.
I bought a RCA switch for a few bucks that I use as an input selector for my computer speakers. I have the computer wired to one input and the ViP722 wired into the other using one of those adapter cables mentioned above. That way you can just press a button when you want to switch sound on your speakers.
I also have some other more involved cables/switches going on - but for simplicity sake I'll keep it at that. The options are there if you want to get it eaiser to use. Try www.monoprice.com for parts, as they have good quality and great prices.
Strange occurrence with Sat 72...
