How to Get Recordings off of 942 to Computer | SatelliteGuys.US
You can use the video out ports on the 942 if you have a video capture card in your PC. You will basically have to play the recordings on the 942 and record them in real-time on the PC.
If you are thinking of using the USB interface or swapping the hard drive - the answer is no.
That might be a option.
I do have a TV tuner card could that also be a option?
Also is there not a eathernet connection on the 942? If so what is is it used for.
I will play with it tonight. If I get time. The MAVS are playing :D
Lost many channels, but got other channels..Why?
What will D* install for free?
