How to hook up 2 DVRs and a single receiver with a Quad Lnb..? | SatelliteGuys.US
My X wife sucks
I have a dish500 aimed at 110 & 119 using a Quad Lnb and 2 duel tuner DVRs
and a 625 receiver. What is the easiest and cheapest way to hook these up.
Thanks for any help I can get. :D
What type of Quad do you have a DP Quad or Legacy? In either case you will need a DPP44 and possibly a DP Twin if you have Legacy now.
You will not be able to run the combo you want on any quad as you need 5 lines off the dish to run the 3 receivers. You options are to get a DP quad or DP twin and run that to a DPP44 switch, or run to (2) DP 34 switches which are cheaper. YOu could also get a DPP33 switch but Ive never seen one yet or know how hard they are to buy. Lastly you could change over to a Dish 1000.2 and need no other switches.
"UrgentAction" 721 Swap: Beware Lease Fee
Getting my Dishes off the Roof.
