Are you asking how to remove the diplexer from the back of the STB? Unlock it first and then pull it off. This will expose two connectors: one for the dish, the other one for the OTA antenna. See pictures in the FAQ.
If you have an amplified antenna, you may have to purchase a standalone power supply. It won't work without it.
Ilya, Is the channelmaster 4228 an amplified antenna? Also, if I disconnect the antenna feed from the multiswitch can I just add a splitter and run separate lines to my 3 tv's and bypass the diplexer? Would I gain anything by doing this?
