How to pair a 21.0 remote to a Hopper Duo | SatelliteGuys.US
yardline
195
My mom got a new Hooper Duo and it came with a 54.0 remote. We've split the HDMI out to run to two TV's with one in another bedroom. I understand the 54.0 is UHF and that will be used in the other room. I'm trying to pair an old 21.0 remote using IR to the Hopper Duo to use in the same room as the box. I've tried this procedure with no luck:
On the front panel of your receiver, press the SYSTEM INFO button.
On the front of your remote, press the SAT button
Press the RECORD button
Select Done
I also made sure the Hopper Duo had IR enabled. I've tried flipping the thing on the bottom of the remote from 1 to 2 and back, but still no luck.
Any tips on what I'm missing? Thanks.
Select Done
On the 21 Remote, Hold SAT button til the lights go on, press 1, THEN press # and the lights will blink 3 times, then press record
2 Hoppers w/sling and Dishanywhere
Local Station Program Guide
