How to program TV2 remote to control TV1? | SatelliteGuys.US
BFG
8,208
Orlando
Hey is there any special process to program the TV2 remote to work TV1
Here's what I know so far.
i enable UHF Pro for TV 1 in the menu but how to I change the TV 1 primary remote address to that of my TV2 remote? or can it only be address 1?
I'm doing this for a 322 which doesn't have shared viewing. If I had a 522 or something I know this wouldn't even be a problem
I think I figured it out!
Remove the blue TV2 key and switch it over to 1 and then both remotes are the same
but I can't figure out how to remove it lol...
Okay I fliped the key, but I realized that this just made the remote an Ir remote, so it no longer works in the TV2 location, so not exactly the solution I was looking for...
I guess I can't use a TV2 uhf remote to control TV1, it needs to be a regular uhf remote or I need the green key that says TV 1 UHF Pro
Hmm, I'll try again w/ that first thread you gave and see if it works.
remote codes
Howard TV on Dish?
