I used a WD Essentials EHD to transfer programs from my 722K to my Hopper. I now want to use it with my computer again. However my computer is not seeing it at all. What am I doing wrong?
I've used this also with good results!You should be able to clean up the drive with a free utility. EaseUS has a free tool called Partition Master that should do the trick. Go to Free Partition Magic alternative & free Partition Manager Software for Windows PC, Workstation and Server - EaseUS. or download from Free Download Magic Partition Manager freeware: EaseUS Partition Manager, Disk & Partition Copy and Partition Recovery Software.
RickDee said:You should be able to clean up the drive with a free utility. EaseUS has a free tool called Partition Master that should do the trick. Go to Free Partition Magic alternative & free Partition Manager Software for Windows PC, Workstation and Server - EaseUS. or download from Free Download Magic Partition Manager freeware: EaseUS Partition Manager, Disk & Partition Copy and Partition Recovery Software.
I have the same problem. I interrupted the dish format on a new EHD. Now it has only 500 gb instead of the 1.5 tb available. I want to somehow reformat the EHD to get all of the available space.
Limited time offer
