How to Schedule Recordings Remotely on Hopper 3? | SatelliteGuys.US
reubenray
1,527
1,302
Bella Vista, Arkansas
In a few weeks I will be taking an extended trip in my motorhome. The 2019 fall season will start after I leave. I have been searching on how to schedule my recording with Dish with not much luck.
How do I do this?
I use the dish anywhere app on my ipad, but you need wifi for the ipad and at your house for the hopper.
If you dont have wifi while traveling You could use the app on your phone, but you still need wifi at the hopper.
Reactions: NYDutch
Thanks, I checked "MyDish" and the Dish Network website, but not DishAnywhere. Will it give me the option to record a series? I did a test, but it did not give me the option to record a series.
I will have wifi with me and the hopper at home.
Reactions: TheKrell
Yes you can record series and chose between all or only new. You have to select record first to see those options.
For the different ways you can set up a recording through the app, you can view our How-To here dishanywhere.com | Recording | MyDISH | DISH Customer Support.
It will show how based on if you set it up through the smartphone app, tablet app, or the DISH Anywhere website. - Jasmine D.
Hopper 3 Leased
ABC Harlington TX is back
