How to set Parental Controls on DIRECTV | SatelliteGuys.US
  • Thread starter Thread starter dfergie
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
[FONT=Trebuchet MS, Verdana, sans-serif]HOW TO SET PARENTAL CONTROLS ON DIRECTV[/FONT]
[FONT=Trebuchet MS, Verdana, sans-serif]DIRECTV understands your need for privacy and deciding which programs are seen in your household. Our Parental Controls help you easily block certain channels and adult programs[/FONT]
[FONT=Trebuchet MS, Verdana, sans-serif]Press "Menu" on your remote, then select "Profiles," and look for "Rating Limit," "Lock User," "Viewing Hours," or "Spending Limit" (varies by receiver)[/FONT]
[FONT=Trebuchet MS, Verdana, sans-serif]Follow the user-friendly directions on your screen to choose your options and a personal identification number (PIN)[/FONT]
[FONT=Trebuchet MS, Verdana, sans-serif]Once this is set, you're in control of the programs and channels you view by simply entering your PIN[/FONT]
Source: E-Mail from DIRECTV
Portable/Mobile HD
HDMI Cables
