How to set up motor and store satellites on Pansat2500? | SatelliteGuys.US
Zip 43123. Motor Satcontrol SM3D12.
I can manually use remote turn the motor and find the satllite alright, but I have trouble store the satellite positions in the Pansat and use remote to switch between satellites, every time I use remote to change satellite, the motor go all the way to east and then return to direct south. I have to manully find the satellite every time if I want to go to a different satellite.
Got it! So the Dish tracks the satellites OK just will not stop.
Sounds like you may not have entered your Lat. and Long correctly. Make sure it says Lat. North and Long. West
Other than that maybe you have not set your true south satellite as your reference (Zenith) position.
Viewsat Extreme
Using dishnet dish and lnb with Twinhan 102g
