When the 2 minute warning comes up press select or info.
You will then get some info about the timer and also the options to continue or cancel the timer.
Go into timers real fast and either skip or delete it real fast. Hope you can beat the clock.
If you would have pressed record, it could have recorded both.
Limited time offer
