How to utilize my Textronics Oscilloscope to set up a ku band Dish | SatelliteGuys.US
electronmini
82
11
Now back in Texas
I used to set up dishes a few years ago for Ku band and abandoned this hobby after a awhile. Now I was thinking of buying a satlink finder to easily find the satellites in North America.
Is there any information on how to use my Textronics (Old AM/USN 425) to find the satellites?
Thanks in advance,
Wilson
Have never used an oscilloscope to locate satellites, but would be interested in how this is done. I assume you have to attach it to some kind of downconverted signal?
It would be a good stable platform to sit a satellite meter or receiver on... :D
But seriously, the LNBF is powered by polarity switching 13/18Vdc and outputs a downconverted block of IF from 950-2150MHz. One would need a tuner and power supply to provide a signal for the scope. Honesty, a cheap $30 DVBS/S2 receiver would provide more useful signal tuning information than the scope. The scope would be useful for troubleshooting the system components, but not for signal acquisition.
Reactions: electronmini
It could be connected to the 70 MHZ IF stage of the RX....If it has one....If it's accessible.
The old analog receivers had this. Don't know about digital.
I myself have no idea of the kind of signals arriving. I thought that maybe just the garbled signals could be used to measure/set to dish
Problem is that you are mixing domains. An oscilloscope measures voltage and sweeps time. What you would need would be a spectrum analyzer. That measures voltage and sweeps frequency. A scope would not produce any sort of usable waveform. The spectrum analyzer would produce a series of peaks at each transponder frequency.
In practice, neither one is terribly useful compared to a satellite finder.
is the worldbox finally coming?
Cable TV Box
