How to you keep the same order of fta channels using Channel Master ? | SatelliteGuys.US
Lassar
SatelliteGuys Guru
149
Illinois
How to you keep the same order of channels using Channel Master ?
Occasionally I use Channel Master to add audio channels to my glorystar reciever.
But every time I do the channel order is drastically changed.
Is there a way to do it that keeps the channel order the same ?
I always loaded in the current channel list, added the new channel(s), placed it where I wanted it and simply saved it. However if you have 100 channels and add a new one and place it number 50, all others will be moved up by one. If your just adding it at the end you should be fine. Hope this helps
Occasionally I use Channel Master to add audio channels to my glorystar receiver.
If you keep your sats in order by geo position as many of us do you can re-sort each time before you exit. On the left column right click on "Satellites", click on "sort by position, exit and save.
lost one of the outputs on my INVACOM QPH-031!!!
looking for a remote?
