HR-20 "Season Pass" Editing | SatelliteGuys.US
warkovision
SatelliteGuys Guru
147
Is it possible to change the recording options of a recurring recording after it's initially set up, or do you have to delete it and re-set? It seems that when I hit the info button on a program in the prioritizer, all I can do is delete it. If I do the same in the To Do list, it seems to only effect one event and not all subsequent ones.
List-to do-prioritizer-hit "select" button on selected program-select record series-make modification-then finish
fsn midwest 647-1
thinking of getting dirct tv
