hr-24 screen format question | SatelliteGuys.US
cspiteri
385
4
I have a new hr-24 and am getting white frames on both sides of the picture only in sd . I`ve changed the resolution to 1080i and am getting a 1080i plus pillar box format which I believe explains the white frames along both sides of the picture. how do I get rid of the pillar box and get a full screen picture on sd?? the picture is full screen on hd channels.
The picture is full on hd because it's supposed to be, but it's not supposed to be full on sd.
Nope. It is the second button from the top on the left-hand side or your remote.
DUHHH, it`s clearly marked FORMAT. i`ve had directv for over 10 years and I guess I never figured out how to fully use the remote.
thanks bob!!!
bob;
I had a stroke recently and I guess my cognitive skills still need some more work in rehab. I`m working on full recovery.
Audio/Pixilation Issues
Should I call and try for a better deal?
