HR10-250 - Slow Guide | SatelliteGuys.US
canesfins
28
I just set up my HR10-250. Scrolling through the guide is real slow, not sure if this is normal. There is a delay of a couple of seconds going from screen to screen in the guide. Also, NBC and CBS channels are not appearing in the DVR set up, I assume its because all the guides have not been downloaded yet.
Sorry, but speed is not the HR10-250's forte. It needs the 6.2 software upgrade that the SD Tivo's got. It seems D* has decided NOT to pass along the 6.2 upgrade to the HR10 due to the fact it will be replaced by the HR20 when the mpeg4 switchover happens. My HR10 is sometimes slow and then its almost as fast as my HDVR2, which got the 6.2 upgrade. I can't explain it. Make sure you check the channels you want in the "Channels You Recieve" and "Favorite Channels" list or they won't show up in the guide. Believe me, this is a great HD Tivo. All of us hope the HR20 is as good but it won't have the Tivo software. Good luck.---Ray
installing at9??
Can you keep the DVR on its side?
