HR10-250 problems with Directv supplied antenna
I had directive install a HR10-250 installed Friday with a $49.00 Directv supplied antenna. my problem here in south Florida (ft.lauderdale) is two of the networks are VHF ( Fox & ABC ) The antenna Directv supplied is a UHF only ( pro brand from Eagle Aspen UHF TV2BU HF ) I get the other networks fine ( PBS-CBS-NBC ) i called Directv as soon as the installer left and they insisted to send another tech out next Friday to adjust the antenna. I explained the first tech already tried, but they still want to send another. Directv told me to check the winegard website and that is the only one they use ? obviously the antenna I received isn't a winegard ( its a small square thing with a couple bow ties ) Did the installer install the wrong antenna ? Antennaweb.org suggest a small multidirectional UHF/VHF ( zip 33334 ) obviously i'll have to replace the antenna and the guy at Directv said they wont accept a returned antenna. The Directv supplied antenna is worthless here because I need UHF/VHF. Any ideas on how to handle this with Directv ? or do i just forget about and buy another antenna ? thanks for your help ( past/present )
