My H-10 tuner works fine, I can get all my locals with it...elwaylite said:Does this unit's tuner work well or should I consider buying one for OTA?
thanks
Yes you set up "Should" work, however, whenever working with antennas, the higher the better ...elwaylite said:I am planning on setting up the RadioShack 40" boom antenna outdoors, probably about 6 feet off the ground. What I can tell is that being 20 miles or less away from my channels, this should work great.
Gotcha, As long as it works for you , thats the important part.elwaylite said:It's seven feet off the ground, best I can do in my rental townhomes. Where it's at, if you get hit, should not have been there.
Limited time offer
