HR20-100 and 18" round dish | SatelliteGuys.US
hoppy55
2
can I hook up HR20-100 receiver to the 1st generation 18" round dish?. I am in a motorhome currently hooked up to slimline dish on a tripod with zinwell multi switch and B blockers. Am going to be heading south in a couple of weeks and would like to hook up to round dish on roof when We stop for a short time. Do I still need to run thru multi switch but take B blockers off?
i would say no... i have seen motorhomes that have rotating (dome) satellite and those would work as they auto lock on to a satellite.
check this site out or any related sites like this one:
http://www.satellite-technologies.com/motosat.htm
are you getting HD serivce? if so, an 18 wont work. you need 101, 110, 119 and your HDs would be on 99 and 103.
the multi-switch, you probably dont need anymore if you arent in a 2 dish market.
you could point it at the 101 (b-bands won't matter either way) you'll only get core programming - no locals or HD - If you don't want to see "serching for satellite" on the channels not on the 101 be sure you change the "sat set up" - Good Luck
You can get locals if your locals are still broadcasting off the 72.5 which only requires a 18 inch dish.
also point out that a 18 inch dish wont work just locking on to 103 or 99. 18s will work on 72.5, 101, 110, and 119 for directv.
I figured I could only get the 101 with the round dish. Just would like to get something when We pull off the road for a rest. I may try it before We pull Out of Our site. If it doesn't work I will move the HR10-250 from the bedroom up to the front tv. I have used that one before with the round dish and it works fine. When We get to FL. will set up slimline dish on tripod.
DTV Locals
DIRECTV TV Apps suggestions
