HR20-100 {CE:09:02} - 0x1B? Announcement | SatelliteGuys.US
mike1973
1,107
4
Rochester, NY
Wow, CE releases 2 weekends in a row for the -100!
DBSTalk.Com
Systems in this CE / Version
HR20-100 {CE:09:01} - 0x1B4
Windows of opportunity to download:
Friday; October 26, 2007 11PM - 2:30AM ET
Saturday; October 27, 2007 11PM - 2:30AM ET
Current Probability: 35%
Be sure to monitor the threads and chat room to check on final availability
While you are waiting for the Window to open:
MUST READ AND AGREE TO: - The CE Rules, Faq and Tips Thread... Here
Please join "us" in the CHAT room, about 15 minutes before the window opens... and till... well to the last person turns off the lights...
DBSTalk.Com -
The Contents of the Release: (Differences based of 0x18a National Release)
* Items from CE:09:01
* Items from CE:09:02
Improved
* Overall System Stability
* Prioritizer Screen
* Navigation to PIG (Picture In Graphics) removed. (Trick Play Still works), to improve interfacing with UI
* Several user interface polishing and fixes
* UPnP issue that certain networked devices could cause the unit to hang.
* Recording Reliability
* Improved interactive load time
* Fix for playback stopping early
Updated
* History list now includes conflicting program
* AutoCorrect FF will not "correct" when STOP or REPLAY is pressed
New feature(s)
* DirecTV on Demand
* Keyword search finds category (eg HDTV or sports)
* Left arrow mimics "BACK" when practical
* Long channel name in search by channel
* Ability to hide SD channels if duplicate HD channel with same number exists
* Grouping of Search Results
Notes
* 02 - Release Notes TBA
Note to other sites and users of those sites:
You are permitted to copy this CE Announcement in it's entirety (including this disclaimer) without modification so long as you provide a clickable link to DBSTalk.com.
Started 11:00 Eastern but hang on, seems to be an issue, might have to power cycle, following over the other place...
Gave download error, asked for a red button reset, trying 1 more time. If this doesn't work I'm bailing on this one...
Edit...Being reported that its on hold till 11:30...
The code stream for the -100 and -700 are messed up, nothing there, saying it should be fixed about 10:30CDT, if you haven't hit 90% just red button reset to keep things the way they were .
I just turned on my hdr20-100 and the software down load reformated and lost all of the stored programs 64% - any one else had this problem?
HR20-100 still delayed for the new CE. Please check the DBSTalk chat room for updated status, I'm gone for the night.
So my receiver finally unfroze only about 16 hours later. Any idea if the hr200-100 ce is going to happen tonight?
I hate to be the first to report an issue...
I am having the same problem as with last weeks CE. Tuner 2 loses its signal on the 110 intermitently. 103b channels also will hit me with a 771 without reason as I'm showing that both tuners see 103b as high strength (86% min). A restart of the box will allow it to restore the strength slightly less than Tuner 1's, which was done immediately following the CE download.
Download complete, all good so far.
Once the new version is downloaded and network connection is made, how long before the VOD button appears? I downloaded 019B and made test via internet and everything is good but no VOD option anywhere.Nor channel 1000.
HR20-700 {CE:09:10} - 0x1B? Announcements
HR20-700 {CE:09:09} - 0x1B?
