HR20-100 - Series Intermitently Cancelled | SatelliteGuys.US
EricMCSE76
29
I'm running 0x21 (3/8 CE release) and have been having a lot of issues lately with Series programs all the sudden not recording, but not all the time. As example, I'll go in a day or prior and th show is listed in the To Do List. But, if I go into history after the fact, the show will have a status of Canceled. When I select that show, i have a message stating -
This episode was not recorded because the program was no longer available .(13)
I've noticed this happening most frequently if I have 2 programs set to record on the same channel that come right after the prior one. So, if I have something on channel 5 from 8p-9p and then another from 9p-10p, the first one records and the second will show up cancelled, sometimes.
I've also found that once I start getting the canceled, if I restart the receiver they 'seem' to go away for a few days.
I've only seen that happen when guide data changes significantly.
Try the new CE this weekend and see if you have any better results.
HR21-700 Audio Drop-outs
Media Share bug - CE 021C
