From DBSTalk.Com
LE Risks and Guidelines
How to Force Download an LE Release
Be sure to monitor the Living on the Edge forum HERE at Satellite Guys for changes in probability and go status!
HR20-700 {CE:08:02} 0x186 - Announcement
Systems in this CE / Version
HR20-700 {CE:08:02} - 0x186
Window of opportunity to download:
Friday; August 10, 2007 11PM - 2:30AM ET
Saturday; August 11, 2007 11PM - 2:30AM ET
Current Probability: 95%
Be sure to monitor the threads and chat room to check on final availability
The Contents of the Release: (Differences based of 0x17E National Release)
Improved
Updated
New feature(s)
Notes
Note #2
My apologizes for the first CE, and not properly documenting in the first release notes, that there was a major under-the-hood software update, that are part of some future offerings. 0x184, did carry a slightly higher risk of issues... This version is built off 0x184, so carries the same risk as compared to the National Release... but not as much as the 0x184.
- Items from CE:08:01
- Items from CE:08:02
Improved
- Improved handling of local networking issues
- Super Pillar (top and bottom pillars, squishing image) while in NATIVE mode: resolved
- Improved Jump Back
- Search Results always placing HD ahead of SD
- MPEG-4 Trickplay improvements
- Improved handling of ATSC tranmissions errors to improve OTA/ATSC compatibility
- Stability
Updated
- Removed left menu from "Search By Channel", once Channel has been selected
New feature(s)
- MPEG Audio support for GameLounge
- When in Search dialogs; Color buttons will allow you to toggle between different types of Search
- Added DELETE option to Playlist
- Added DELETE option to ToDo List
- Added Resume/Start Over options for playback of recordings
Notes
- VOD is not enabled in this version (I know you where going to ask)
- Resolutions to issues identified/introduced in 0x184
Note #2
