HR20-ALL / HR21-ALL / R22-100 CE Release 6/13 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE / Version
HR20-ALL
HR21-ALL
R22-100
Window of opportunity to download:
Friday, June 13, 2008 11:00PM - 2:30AM ET
Saturday, June 14, 2008 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! CE Release Warnings & Agreement
PLEASE READ THIS SECOND! CE Release Download Instructions
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
Improved
  • 01 - Stability
  • 01 - Accurate network connection status after reboot
  • 01 - Overall Media Share
  • 01 - Channel change speed
  • 01 - Tuning and Recording Robustness
  • 02 - Stability
  • 02 - Fixed incorrect blue background
  • 02 - Fixed R icon not displaying in Folder during recording of a event in Folder
  • 02 - Fixed unable to Clear Delete Marks in Folders in Mark And Delete Screen
  • 02 - Fixed unable to modify extension on single episode of a booked series
  • 02 - Fixed modifying extension of already booked series does not update episodes already in ToDo
  • 02 - Fixed black screen shown when blackout is removed
  • 02 - Fixed no Kepp or Delete On Screen Display OSD after FF4 to end, RW, Pause, then Advanced
  • 02 - Tuning Robustness
  • 02 - MediaShare – Fixed unable to play slideshow in PIG when browsing thumbnail
  • 02 - MediaShare – Fixed wrong song ordering
  • 02 - MediaShare – Fixed blank thumbnails
  • 02 - MediaShare – Fixed FF of pictures jumps back instead
  • 02 - MediaShare - Stability
  • 03 - Fixed channel banner program information being incorrect after using previous button
  • 03 - Stability improvements, including issue after deleting in response to K/D OSD.
  • 03 - Fixed recently searched keyword not saved in previous screen
  • 04 – Fixed stuck boot 1 of 2
  • 04 – Recurring manual records no longer share playlist folder
  • 04 – Faster deleting large folder from playlist
  • 04 – Improved history for manual records
  • 04 – Stability improvements
  • 04 – Fixed DIRECTV On Demand results list
  • 04 – Fixed issue where KEEP ICON is missing after using mark&delete
  • 04 – Fixed mini-guide with guide tip
  • 04 – Lipsync improvement
  • 04 – Media Share Stability
  • 05 - Added ability to send a Diagnostics Report back to DIRECTV - See notes
  • 05 - Added New Release category for DIRECTV on Demand homepage
  • 06 – Stability
  • 06 – Audio
  • 06 - Mediashare compatibility with Nero MediaHome
  • 07 - Recording robustness
  • 07 - Favorite List handling of hidden ATSC channels
  • 07 - Auto-recording titles with symbols e.g. Law & Order
  • 07 - Mediashare media access issues
  • 07 - Removed HDCP warning during HDMI negotiation
  • 08 - Stability
  • 08 - Synchronize all the HR2x to CE:14:08
Updated
  • 01 - History messages for recording and deletion events
  • 01 - Close Captioning Left Placement
  • 05 - PC Mediashare is back
  • 05 - Faster category search and sort
  • 05 - Faster loading DIRECTV on Demand listing
  • 05 - Program Info Screen text
  • 05 - Stability
  • 07 - GameSearch
  • 07 - User Interface various issues addressed
  • 07 - Installer Dish Setup
  • 07 - Issues with rebooting
  • 08 - GameSearch
  • 08 - User Interface (various issues addressed)
  • 08 - Installer Dish Setup
  • 08 - Issues with rebooting
New features
  • 01 - Triple Tap support e.g. title/name/keyword search screens, favorite list naming, etc
  • 01 - Search for PPV Movies in guide options panel
  • 02 - 1-touch record hint for program cells/items
  • 02 - Add "Move to Top" hint OSD in the Prioritizer screen
  • 02 - Add a display settings option in the System Setup screen for the enabling/disabling of the 1-touch Record Tip OSD
  • 03 - Daily Fortune
Notes
  • 01 - This CE cycle is expected to contain new features
  • 04 – THIS DOWNLOAD WILL REMOVE GUIDE CACHE AND THE GUIDE ACQUISITION WILL TAKE LONGER
  • 04 – BOOT STUCK WARNING: If you could not boot with the last CE with network attached, and had to revert to national to be able to boot with network, do not try POKEEYENOW. If you try it, your HR20 will probably still hang/crash on boot. If you insist, then you will have to boot without your network and POKEEYELATER to correct.
  • 05 - Send Diagnostics Report:
    requires IAMANEDGECUTTER keyword search to be enabled
    *** Network must be properly set up and working to use this feature ***
    1. [*]Use the Menu+Info keys to get to the Misc Options screen
      [*]Select the Report option
      [*]Click on Send
      [*]Wait for it to finish
      [*]You will receive a confirmation key in your response.
      *** Please include this key in any post you make in the issues thread ***
      [*]Please note that you can only send one report per 24 hours
      [*]If you do not have a network connection, you will not have this option
HR20-700 0x0247 Discussion thread
Guide data intact.
Channel Banner seems to respond faster.
Media share see my Palm video folder.
Yellow record light that had turned more of an amber color after the last CE is now back to more of a yellow color....odd, but okay
System Test is stupid fast now
No problems with navigation/channel changes
HR21 folks, check our guide data, a number of folks have reported that it's not working, showing just regular schedule.
Just finished on my HR20-100 an all seems fine so far.
Got my HR20-100 downloaded at 11:02pm friday. Best feature for me has to be the info logo showing up with 1 button recording so you can finetune the recording setting by just pressing "info". It was always a hassle to get extra time on a recording after simply pushing the "record" button on a program from the Guide. Now it's a 1 button click to accomplish thisand the receiver will remind you everytime you push the "record" button. Excellent upgrade feature!:up
Cheers,
Robin
I have a Service call scheduled for next week because my On Demand and Caller ID don't work at all on my R22-100. I am not sure if I should leave my receiver at the National Version or if it would be ok for me to do a CE update. I really want to test the latest CE update, but don't know if they would mess up my R22 even more or if the repair man would like it?
What should I do???
I am realy considering this and have a question..
Has anyone lost there recordings doing this?
Also has anyone lost there Prioritizer from doing this?
(assuming you did not select reset everything by accesdent ")
Lost prioritizer - never heard of that.
Lost recordings - heard of it once and had it happen once to me. The repsonse from the developers is that if there is a data error on the drive it wil format during bootup. Although I lost my data and thought it was from a CE, it very well could have done it during a regular reboot too, so it was inevitable. I've only ever read of that happening to one other person in the year + of the CE program.
It is pretty safe. Not 100%, but 99%+.
The worse thing he will do is reset it to the national release. The window for this CE has closed so now you would have to wait until Friday for the next possible release.
Email notifiction - feedback request
CE Bug: Channel Blocked issue
