This was a misprint in the manual - you can only record a max of 2 things at once, whether they are on the OTA tuner(s) or from the dish.
You CAN, however, still watch a pre-recorded prog while you are recording 2 live shows.
Correct, and yes it was a misprint.
Jimbo
Well, on my new HR unit and 5 lnb dish, I can only record one show at a time. On a system check I get a "failure" reort on "tuner 2 - sat99b. I suppose that is the reason? Can I do a fix here or must I return the unit?
Limited time offer
