HR20 New Software ver. 0xEB (Several Fixes, no OTA) | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Earl over at DBStalk once again has the scoop.
http://www.dbstalk.com/showthread.php?t=69545
Several fixes. Hopefully the key one for me is the searching for satellite signal will be eliminted - a huge problem on MPEG4.
It says that this is a staggered release - may be a little while to get it without a forced update.
Here is the release notes from over at dbstalk:
Program deleting from the MyVod before user action or delete criteria reached (space, SL settings, etc).
Prioritizer will remain in-sync with the todo list
Upon initial playback, content doesn't play and displays "DELETE" On-Screen Dialog
Additional Miscellaneous fixes (no specifics provided)
Improved accuracy of hard drive usage indicator
'Searching for satellite' message no longer appears while viewing a recorded program.
Improvements to Manual Recording Scheduling and reliability
Additional stability fixes
Improvements to HDMI compatibility.
All A/V Outputs are disabled when the unit is put in standby mode
Unofficial Support: eSATA will properly reflect full size of connected drive (or RAID)
well i just did it.. and nothing happened... :(
On the HD DVr i mean...
It hasn't rolled out to the Central Time Zone yet.
Also, the HR20 will auto-update as soon as it is authorized. (it tried every hour after it gets the Okay to update)
Probally a few days, they will start on the west and work across. It lets them space out tech support calls if there were to be problems.
I activated another new HR20 receiver last night that had never been in the stream. When I did a force download BEFORE activating it still wouldn't get the new version. I guess they are very specific when they do a limited rollout.
I got it yesterday early morning.. here in SoCal.. :hatsoff:
R15 - No Live TV button ??
Connecticut Locals In HD??
