HR20 newbie operating Questions | SatelliteGuys.US
joseph.solari
17
1. How do you delete a show/season ticket you set up??????
2. I told my dvr to record Little Bush all new shows and it hasnt recorded one yet? Is this a problem with comedy central and the information that they present for there channel?
1. Hit List Button - Yellow Button and then Prioritizer. You can then delete a item by going into it or hitting the - button. You have to use the - dash key if you dont have anything in the prioritizer item.
2. Comedy Central info is always screwed up. Make it both instead of just first run. You can always deleted items.
Which sat carries ESPN game plan?
Would this work?
