HR20 thru HR24 CE Release 4/29 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
HR24-100 • HR24-200 • HR24-500
Window of opportunity to download:
Friday, April 29, 2011 11:00PM - 2:30AM ET
Saturday, April 30, 2011 11:00PM - 2:30AM ET
Risk Level for this Download:
Customer Candidate
New features
None for this release
Improved/Updated
Under the hood
Notes
This CE will remove your guide cache if you did not download a previous CE. Please allow up to 24 hrs to restore your full 14 day guide.
You will lose your guide cache when reverting from CE to national.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
This is now a unified issues thread for all current HR2x and R22 DVR's
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:26:01(0x046B)
Enhanced Channel Banner!
Improved/Updated
CE:26:11 (0x048F)
Trickplay bar
Esata issues
I checked before heading to work this morning, 04A6 on the HR24, I started the dl then shut that tv off & went back to bedroom... reason HR20 didn't want to dl was getting no signal on 1 (no time to check till next weekend) I reverted back to last weeks dl on it.
Systems in this CE
HR20-100 • HR20-700
HR21Pro • HR23-700
Customer Candidate
New features
Improved/Updated
Under the hood
Notes
you can also call or go onto the directv site and resend you guide data fromthose two options but if there is a bug is the CE release then you will have torevert back to National release
Had something interesting happen tonight. I went to watch tv on the DVR (HR-24) that is on the CE release, and wanted to watch something from the other DVR (national release). When I pulled up the "list", it showed ONLY an old show that I had deleted off of the other DVR in the list, and would not play it as it "could not find it". Would not refresh the list to what is currently available through several exits and returns to the list.
Rebooted the DVR on the CE release using the red button, and now it shows the proper shows in the list.
CE's for the Last Weekend of April
CE's for the First Weekend of May
