HR21 Any Way To Change A Recorded Title | SatelliteGuys.US
bk63ross
SatelliteGuys Guru
148
San Francisco
Is there a way to rename or hide an already recorded program from the archive list on the HR21? On the 622 I used to able to change the name...
what if u category sort the list ? there is a "content advisory" sort ...maybe that would put them all together at the end of the list.
I think if you lock the receiver for certain ratings, it will display "blocked title" or something close that - and only play it with the pin number.
I will give it a shot as I have tried all the other sorting categories with no luck. Maybe the Techs can figure out a way to simply rename whatever you want or need and add it in the software updates.
Though I'd only use it once in a great while, this would be good for when my local stations preempt shows for weather coverage and then air them at a later date. Now, I have to remember that "Manual: DaVinci's Inquest" is actually an episode of Lost.
Wireless Internet to HR20-700
Yellow Light On Dvr
