Hr21pro,ANY INFO? | SatelliteGuys.US
Hr21pro,ANY INFO?
Bill1767
SatelliteGuys Guru
134
Weston,FL
Does anybody own this receiver,I'm being told that this is not a lease?.I would like to buy this receiver and own it if possible and how reliable is this unit .
you are correct....it isn't a lease. believe the cost is $599.00. sounds like a nice unit. but i'm not sure when it will be available. i'd like to buy one.
You can buy them now:
Solid Signal HR21 pro
They are an owned unit.
Very similiar to the HR21, if I remember right has a bigger hard drive, metal casing that is mountable, and option to use optical HDMI to cover long distances.
Other than that, it's about the same.
Unless you specifically want to own, I'd get a leased HR21 for $199 and an external hard drive around 1TB.
Big Brother is Watching!
HR21-100 Audio Muting
