HR22 HD-DVR Ethernet Connections | SatelliteGuys.US
rbredding
3
Georgia
In the rear of the unit, there are two internet connectors, is this a "pass through"?
the top ethernet slot is for incoming internet connectivity.
is the bottom an "out" slot that can be used to connect an additional "network equipped" unit like my Blu-Ray Player ?
Thanks.
(I did several searches but couldn't find where anyone asked the same question before)
The second is a passthru to another device, say like an xbox.
I don't have any gaming systems....
but I used it as a pass through to my Blu-Ray and it (BR) was able to download the firmware update so I figured it was exactly that, a pass through.
Thank you for the quick reply..
Local
DECA and MRV setup
